pucho812
outside of the burr brown chip opa604, are there any other opamp ic's that can handle and will run off +/- 24V?
volker said:That's easy enough to find out using the parametric search of any bigger distributor. Off the top of my head, TI has some more: OPA551/552, OPA445, OPA454 (high power).
If you're content with 44V, there is much more to find.
Kingston said:you could run those DOA's at 44V. lose only 1dBu of headroom compared to 48V and you don't need to settle in for second rate or outdated opamps.
college101 said:Not everyone understands opamps yet...were in that chapter right now in class
college101 said:Opamps can be used as Voltage amplifiers! BUT what we really need to know...what are you trying to do with the opamps at 48V...Like a few chaps on here suggested...Having a supply line at 48 volts is excessive...a better idea would be to run a lower line and then step it up...
Andy Peters said:college101 said:Having a supply line at 48 volts is excessive...a better idea would be to run a lower line and then step it up...
I don't quite get what you're on about there.
-a
What would be the point of operating the DOA's at 48 and the rest at 44? Headroom would still be limited by the 44 rails.pucho812 said:college101 said:Opamps can be used as Voltage amplifiers! BUT what we really need to know...what are you trying to do with the opamps at 48V...Like a few chaps on here suggested...Having a supply line at 48 volts is excessive...a better idea would be to run a lower line and then step it up...
Yes they can.
48V max so bi-polar +/- 24V. anyway the idea was/is simple to it run from a single psu source of +/- 24V. since the units in question are a mix of discrete opamps and ic chips, why not have ic chips that run on the same voltages as the doa's and drive down cost a bit. however after some thought I am rethinking my issue.
abbey road d enfer said:What would be the point of operating the DOA's at 48 and the rest at 44? Headroom would still be limited by the 44 rails.pucho812 said:college101 said:Opamps can be used as Voltage amplifiers! BUT what we really need to know...what are you trying to do with the opamps at 48V...Like a few chaps on here suggested...Having a supply line at 48 volts is excessive...a better idea would be to run a lower line and then step it up...
Yes they can.
Asked and answered... If trying to optimize peak output level you can normalize voltage gain between them so they both saturate at roughly the same time.pucho812 said:abbey road d enfer said:What would be the point of operating the DOA's at 48 and the rest at 44? Headroom would still be limited by the 44 rails.pucho812 said:college101 said:Opamps can be used as Voltage amplifiers! BUT what we really need to know...what are you trying to do with the opamps at 48V...Like a few chaps on here suggested...Having a supply line at 48 volts is excessive...a better idea would be to run a lower line and then step it up...
Yes they can.
now someone is thinking on the same idea as me.
