ibvee said:I've come across some phantom power supplies which didn't put out exactly 48V at all. More something between 45V and 50V. So I was wondering why 6k81 is the standard resistor, instead of a 6k8, which works fine too, and is usually cheaper?
Rossi said:I usually reach into a 100 pieces bag of 1% resistors an measure about 10 until I find two that are identical within my DMM's accuracy. I do that both with the 6k8 resistors in a preamp and the phantom sourcing resistors (often around 2K) within a mic I'm building.
I know that 1% unmatched will do in most cases (and many manufacturers be content with that), but I like to know that my stuff is a little better than absolutely necessary. And why not, if all it takes me is a minute or two of measuring?
[silent:arts] said:Your NV73 needs either the input or output pin1 connected to GND, not to chassis like we & Rane always recommend.
sisepuede said:[silent:arts] said:Your NV73 needs either the input or output pin1 connected to GND, not to chassis like we & Rane always recommend.
Thanks mate, yeah I did that, David ( NV73 Maker) told me that because if not the NV doesn't work at all, so I did that (audio GND, Chassis and PSU GND all together) and it worked fine with dynamic microphones, but at that time I heard some noise in the background, kind of 50Hz, then I connected a condenser and when I turned the 48v on that was a massive noise like a "boat's motor" (Thanks Cemal for that expression)... since then I am trying to figure out what the hell is causing that fu**ing noise.
I've uploaded some pics in my gallery, you could check those out to see how I did it, I have a frame where the NV73 is in test mode, with a card edge connector and it really works fine (no funy noises, GND loops or static noises) with the DIY51X PSU, but the phantom power, that's the only bad thing.
By the way tomorrow or on Friday my 511 Rack will arrive from Scotlandhopefuly I'll have this sh*t sorted out.
cheers.
JohnRoberts said:The matching of phantom power resistors can degrade common mode rejection so main symptom of poor match will be extra hum pickup.
6.8k value is based on nominal 48V phantom, but many industrial applications use lower voltage and lower value resistors, FYI.
