500 series info
glazer56
San Jose, CA
Hey all,
Have a quick question; does anyone have the distance the card is from the centerline for the 500 series units?
Have the following info, but not sure how far the PC Board is from the edge of the unit. Many thanks!
500 MODULE SERIES SPECIFICATION
Overall Specifications:
CARD EDGE 15 PIN .156" SPACE
306-015-520-102 EDAC type
EDGE CONNECTOR PIN OUT
TERMINAL          FUNCTION
1                    CHASSIS GROUND
2                    OUTPUT + (+4 LEVEL)
3                    OUTPUT + (-2 LEVEL)
4                    OUTPUT -
5                    COMMON
6                    525 STEREO LINK
7                    INPUT- (-2 LEVEL)
8                    INPUT- (+4 LEVEL)
9                    INPUT+ (-2 LEVEL)
10                  INPUT+ (+4 LEVEL)
11                  GAIN TRIM RESISTOR
12                  +16VDC
13                  POWER SUPPLY COMMON
14                  -16VDC
15                  +48VDC
Maximum Power Consumption Per Unit: +16VDC@130mA
          -16VDC@130mA
        +48VDC@5mA
Size:
Front Panel      1.5”x5.25”x.125” Thick
Depth to Rear From Mounting Surface 5.938” +/-.02”
Here's a mechanical drawing for one of our 500 modules.  Blue is the PCB, magenta is the main chassis, green is the front panel.
  • Speck ASC-V Mechanical.pdf
    17.5 KB
Write your reply...
