5k log-antilog dual gang pot
Deepdark
Quebec, Canada
Hi guys
Do you ever see such a pot? In got a pa2 from tl audio to repair one broken pot. No succes to contact sonic systems (their services contact) so i ask here if you ever see them, know where to find them. The pot control the mic in and the instrument in. Alternativelly, i could wire the mic in with a rev log and the instrument in with a log but before doing such a thing, i must ask here before.
I dont know if it could be possible to take off the rear gang (antilog) and put it on a brand new dual gang log pot, by swapping the rear log gang with the antilog
You can, at least in some pots, I've done it. The tricky part is to put the shaft back in place so the pressure of both sides is good and doesn't wobble around, so you need to get a good position and the center plate perfectly parallel with the other plates.
JS
PS: I miss to say is not the most reliable solution but for one off trials is good enough, not a nightmare but be prepared for one or two missed trials.
Just to let you know that I repaired the defective pot. The shaft was completly out so I pushed it back in place and realligned the gang. Everything works just fine now :)
