Tomba
Member
Hi everyone.
Has anyone ever done a Fairchild 670 with solid-state side-chain? It would be so much cheaper because you will need only half of the transformers and only four 6386's as you all know. I think few high voltage op-amps could do the job. And you don't have to charge the caps on high voltage if you place the voltage gain amp after caps.
What could be the benefits of the tube side-chain with i/o trafos? Have anyone calculated the voltage gain of the side-chain amp?
