tablebeast
I have a Stromberg-Carlson AV-38 mixer that I would like to convert. Currently it has three mic inputs and a phono input with a low and hi EQ and no master volume. The four channels are each based on 1.5 sections of 6SC7 tubes running into a 6SC7 phase inverter tand then to a 6N7 power tube in push-pull going to an output transformer. It has a gigantic amount of gain for each channel as-is. What I want to do is gut it and start from scratch. I would like to have 3 mic pre circuits that use 1 to 1.5 octal tubes and use the fourth channel as a direct recording guitar amp. Each mic input has a center tapped input transformer that can be set up for 1:14 or 1:28 use. Obviously I'd like to use them as 1:14 to preserve bandwidth. Putting the guitar amp circuit aside for now, I'd like to develop the mic pres first. I'd like to base the mic pres on either 6SL7 or 6SC7 tubes. I figure the main difference between these tubes is the common cathode in the 6SC7. I'd also like to have unbalanced outputs without output transformers. I searched the archives but came up with little info on using these tubes as mic pres. I'm not particularly looking to clone a commercial device from the past, I just want something cool and funky for guitars and maybe vocals so a slightly compressed/distorted sound would be cool. I have the Sam's photofact of this that I can scan if that would help. Thanks in advance.
Jesse
Jesse
