systemtruck
Hi all,
I’m modifying a Hewlett Packard 201C, which is an old tube oscillator unit with a nice strong PP output stage with a 600 ohm output impedance. Going to delete the whole osc section.
Utilizing just the output stage, by cutting the osc signal and inserting a line input, it already sounds pretty great going into a 600:8 line to voice coil transformer and into a speaker.
There is a negative feedback pathway with just one resistor of 4700 ohms. It’s not a divider, just a resistor in line from transformer output secondary (or maybe it’s a tertiary) and into the cathode of preliminary stage.
The cathode is otherwise not connected to anything else. Thus it is not a voltage divider setup.
I’d like to experiment with making this unit flexible on the fly….. louder and dirtier to use as a guitar amp, but also to retain a somewhat cleaner sound for HiFi playback. Appropriate preamp stages assumed, to be built once I settle this output stuff.
I followed the suggestion of another tinkerer and snipped the feedback line and grounded the now loose end of the NFB resistor so that the cathode now has 4700 ohms to ground. This increased the gain greatly and allowed for excellent distortion/drive/breakup of the output stage where as I wasn’t able to distort it at all before. This is a great guitar amp version. There is some noticeable hum though, as to be expected with all this gain I suppose.
Is the NFB transformer winding bad to leave disconnected? I’m unsure if it is a tertiary or if it is actually just part of the secondary. Schematic makes it look like it’s just the bottom half of a center tapped secondary.
1. Would it be better to handle that now disconnected lead somehow? Ground it?
2. Would it be better to never snip this NFB line and instead put in a “variable” resistor? I’m unsure what the current going through that line is and if any pot can handle it.
3. If I can put a pot in as a variable resistor, how high of a value will effectively create the same extra gain as snipping the line? And is that perhaps better for noise / hum than snipping the NFB line outright?
Ideally I’d be able to have a pot active at all times that was simply an NFB resistor. Great for experimentation immediacy too. Adjust for guitar amp, and adjust other way for clean lower gain. But if current is too intense, I could create a switch with a few beefy resistors.
