Twenty Log
Howdy Folks,
I have a simple 7x7 relay routing matrix (7 inputs route to 7 outputs; re-assignable any input to any output). One issue (maybe?) is that during the switching to reroute audio from one input to a different output, it is possible that 2 output op-amps can be shorted to the same signal, if there is a make-before-break or a relay failure (stuck relay).
I was originally (on paper) putting lots of precision resistors on the routing output of EVERY relay and essentially turning the matrix essentially into a mixer that should normally have normally only one channel mixed per "bus", but am looking to only have a common resistor at the Input of each bus in the matrix only to reduce parts count...
Basically the two opamps shorted together in the reduced parts count scenario are 2 parallel current-to-voltage converters (transimpedance) amplifiers with their "virtual ground" connection shorted together with a common resistor on the input as fed from the matrix...
I wonder if the error offset voltages and currents inherent in opamps will make the two opamps fight each other through the virtual ground when shorted at their virtual grounds (with single common resistor as the input resistor to the shorted pair)... Will this cause oscillation (note, I have omitted feedback caps and other protection circuitry)?
Here is a picture (worth 1k words?) of both scenarios... I like the reduced parts count, as when this matrix becomes a 7 x 7 matrix it gets hairy (especially when balanced topology used)....
Any thoughts anyone?
-chris
-chris
