REVISED TUBE CONSOLE SCHEMATIC- Questions???
I just watched EBay for a while. The ones in the pic are true vintage, but I have a few repro that look pretty legit! Got most of them pretty cheap, but paid more than I would have liked to for a couple.
If you feel like sharing a link for these repro, I am interested because I never dared to pull the trigger. To know they are validated by someone owning / touching / using the the real ones would help me :)
Dont want to hijack the thread, though !
Unfortunately, the repro ones I found were also second hand on EBay. 😕
I just did a brief look and didn’t see anything up for grabs at the moment.
Note that if you insist on grounding input center tap, that you'll compromise
- Phantom power will be shorted
- unbalanced (e.g. minus to ground) will not work
-your cmrr can be significantly impaired depending on the precision of transformer winding and symmetry.
I have an old AKG phantom power supply that I’d be using ahead of the console before the mic inputs, would this still not work???
..sorry for persevering, but your grounded-centertap input transformer continues to bother me: Even with an external, capacitor-isolated phantom power supply, it relies very much on a 100% floating and symmetrical source
Which means that any impedance-balanced electronic balancing will partially short out.
So incompatible with all the new Neumanns etc..
/Jakob E.
/Jakob E.
I appreciate the perseverance! So would I just need to leave that connection off to fix the issue? Or would this require some rerouting?
Thank you!
for a mic input, I can't see any scenario where you'd want the grounded primary. Never seen such connection irl
Agreed, but just to note, almost all of the RCA tube preamps are CT grounded. The output side frequently is too. With some of their inputs, the shield is attached to that CT such that you must leave them grounded. Not a modern thing at all, not a thing that exists after the arrival of T-power or 48V. You do see the CT used as the 48V source, with half the series resistance.
Okay. Thank you for the input! That would make since because this is based off of an old modular RCA design that uses an RCA input transformer. So I should leave this connected is what you’re saying? And just not use anything with phantom power running through it?
..as I understand it, 48V-through-center-tap won't work with impedance balanced mics like the Neumanns, as the "dead" side will short half the primary..
Ah, so that super-cedes the original 48V CT idea. I've got a few things that are CT fed, I suppose they've not encountered a mic like this yet. That also means those mics accept only half the potential current? Or it's a power path but not an audio path? I've not looked at a schem....
