user 37518
gyraf said:..I raise you with a single-node servo cct, attached...
/Jakob E.
Interesting...
What's the benefit VS a conventional DC servo?
What about stability?
/Jakob E.
That's an interesting trick. Stability is unquestionable since it involves only one opamp.Dualflip said:Interesting...
/Jakob E.
JohnRoberts said:Operating in the digital domain with some rudimentary logic (maybe a small microprocessor) you can use the output of the ADC itself to perform a self calibration with input (shorted). Using digital pots you can correct a decent range of DC offset errors. This will be fine for relatively short term measurements, but long term stability has other variables, like temperature coefficient of components and even devices.
