Hi Group Diy,
I was wondering if anyone could help with some wiring related questions.
Nearly finished building a GSSL with Turbo and 2x Super sidechain (SSC) boards, just doing the final wiring but I'm a bit confused about the best way to hook up the 2x SSC boards and Turbo board with a Turbo/GSSL DPDT switch.
I've hunted around the forums but there seems to be many ways to skin a cat. Some of the diagrams/descriptions out there are a bit confusing or questionable and many are for a different configuration than I am building.
I found one diagram that I've made a modification to because it seemed to have L+R points for SSC on GSSL board the wrong way around. Otherwise it seems like it should work to me but I am a bit of a newb to the diy game, so I more than likely have got something wrong... Trying to use this and other projects as a way to learn about whats going on in the circuit rather than just blindly follow instructions and hope it works.
Can anyone see any mistakes in this diagram or confirm that it will work before I start soldering it up? Here's the image:
This is the Sidechain board I'm using:
https://plus.google.com/photos/108309409331755720628/albums/5181806817133197329?banner=pwa
My second question is about the EAO switch I'm using. I bought it from ssl spares and it has a few more lugs than I was expecting or need and am a bit confused about where to solder. There doesn't seem to be a datasheet available from EAO for this model either… There are 5x pairs of lugs. 1 pair on the rear are labelled "+" and "-" which I presume are for the led lamp? Another 4 pairs, one pair on each corner are labelled 1, 2. 3 and 4. Are these maybe 4x switches and I can just pick a pair and solder the "To" and "Return" points on SSC board?
If so does it matter which lug I solder "To" and "Return" on SSC?
Here's a couple images of the switch…
My third question is about the External Sidechain input on SSC boards. I'm using an XLR input which is grounded in series with the other XLR's. Do I just parallel wire Pin 2 (+) on XLR to "Ext." on each SSC board and leave XLR Pin 3 (-) and the "0V" point next to Ext. on SSC board unconnected?
My final question is regarding a problem I encountered. Whilst wiring up the rotary switch pcb, the ON and COM solder points came away from the board.
I traced the ON point to the "C" wire in the ribbon cable and the COM point the pole of the attack switch. Can I desolder the "C" wire from rotary pcb and connect it directly to ON point on SSC pcb and connect the Attack switch pole directly to the COM point on SSC and this will be ok?
Many thanks in advance,
Sam
Sam
