k brown
In my continued 'messings-about' with the Behringer B-5, I noticed that one of my older, through-hole versions produced a very loud, sustaining pinging noise when tapped (quite distinct from mic-body ringing), the other didn't do this at all. Nor did either of my later examples with the SMD board.
Then I remembered that I'd swapped out it's nasty little ceramic capsule cap with a styrene, and hadn't done it yet with the other. So I tucked a small blob of Coax-Seal between the styrene cap and the board, and also a tiny noodle of it on the lead connected to the capsule. Pinging gone!
https://www.amazon.com/Universal-Electronics-Coax-Seal-Moisture-Sealing/dp/B004FVMALW/ref=sr_1_8?crid=3MD5S8COCRGP9&dib=eyJ2IjoiMSJ9.8cLRCTzjbDEeiZLQTKrblwHUBz7UuVzakZFNg5f4Q5hpH_bTZqCfyPdUNhXso2KDgy8C1GzQ81YFzK2Wh-fRnTBFbCNqXJkVuCiPgzexD84727M0HPkchySYeBJGPP_e6Wv8zCqHenvHhTX-OjhKVPrSZpfUfZTV2Auc6qjxPdv8B-fb5EwZXAESlbI-oj71HWDXtnwiGmNHf4dxcKaMPoQT81UJ0bOI8z_XExXwCEA.neylVKrpqYcZPrFivGuLuCke7mGLPM0QKzPJILtNc0g&dib_tag=se&keywords=coax-seal&qid=1720551176&sprefix=coax-seal,aps,208&sr=8-8
The noise was so spring-like, that I thought there was something about the spring in the original model's capsule connection pin that was the culprit!
Probably the reason this pinging was so pronounced was that I hadn't soldered the styrene into the original cap's PCB holes, but connected it 'in air' between the capsule connector pin and the board.
The newer, SMD boards come with a nice little COG ceramic for the capsule connection.
