There is a misunderstanding about the "audiophile" power cables. People say what difference can you have with an "audiophile" power cable if you have kilometers of cheap wire from the power plant to your house. This interpretation is totaly wrong because those "audiophile" power cables are not made to plug your equipment into the wall.
The idea is that the power line is contaminated with lots of interferences from radiostations, CB radio, computers, motors and other sources. The idea is to use a power conditioner that will filter/isolate out all the garbage and produce clean power. You should use those "audiophile" power cables between the power conditioner and your audio equipment.
Those "audiophile" power cables are shielded, have large diameter wires, have hospital grade connectors and ferrite rings at both ends of the cable.
All these will help to filter out any kind of RF and other noises. A good power conditioner design will not only filter the garbage from the power side but also will filter for example noise produced by the CD player into the other elements of your system.
Next question is, it is justified to spend 600$ for a power cable. In my opinion it is completely absurd as long as you know how to make a quality power cable. You need a pair of hospital grade connectors, large diameter shielded power cable, a pair of ferrite rings and some heat retracting tubes to fix the ferrites to the cable. Even if you use the best quality components you are below 100$.
Do they work? Before I answer I have to say that I am totally against audiofool bulshit so I always try to find the logical answers for these problems.
I am lucky enough to have access to some absolutely high end systems, one of them is made of Wilson Watt/Puppy speakers, Spectral power amp (designed by Bcarso's friend, the recording and design genius Keith Johnson), Boulder preamp and DAC, Clearaudio turntable, Siltek cables, all the system is vibration isolated with air, no mechanical contact with vibrating elements. The other system is an even more refined one.
We regulary make tests to see how things influence the sound of the system.
The difference between an ordinary power cable and a shielded quality cable is significant. It is not about placebo, the difference is big enough to take it seriously. Probably all the noises that enter into the system are responsible for the loss of stability in audio circuits (they have to work not only in audio but also in the RF zone), loss of detail and distortion.
I am against paying stupid prices for cables but I am for making similar quality cable with much, much less money. They work.
Audio cables and speaker cables have to be designed taking in consideration the same things. Large diameter conductor, low capacitance, quality dielectric, good shielding, ferrite rings, quality connectors. They also have a significant influence.
chrissugar
