Chris
Star earthing takes the most work and gives the best results.
I use a version where I would connect the input signal earth to the bottom of the first stage cathode resistor, then take that to the star point etc.
I usually make the negative of the first filter cap which connects to chassis as the star point.
If you dont want to do a full on star earth, make sure you seperate the power supply and signal earths.
On the Laney the can filter caps are individually connected to chassis and this makes what I mean by seperate power supply earths.
Good earthing not only reduces hum but also back ground noise, the subjective result being that you hear more of the sound of the instrument.
And not all vintage Marshalls have a thin and glassy sound!
Recently I have had two JMP's in my workshop and they did not sound thin or glassy
Sorr
Sorr
