Steve Hogan said:
I will now write a second post with all the rest of the stuff that I lost.
Q4, Q5 oscillations, 81 EQ board, clipping indicator, and audio coupling cap issues
I pulled all the '81 EQ cards and shotgun replaced Q4 and Q5 and D3 with my recommended replacements in my primary test-bed '81 (Thanks Crazy-doc).
I didn't check for oscillations before replacement, since I was on deadline to finalize the transformer winding voltages, so I will have to observe the problem on one of the other '81s here for repair/upgrade, since I have no desire to replace the new parts with the old. I have a couple of questions from those who have already tackled this problem:
1. Is the oscillation problem consistent and repeatable?
2. Is it a low frequency (motorboating-type) oscillation or a high frequency oscillation?
3. Anyone put a scope on it so I'm sure that I am identifying and solving the problem thoroughly and completely?
I have the following observations about the EQ cards:
1. Due to the long, daisy-chained power supply and signal busses on the 81 preamp, and the presence of a 47 Ohm series resistor isolating each EQ PCB from the 24V Buss, I believe it would be a good thing to up the value of the 100uF/35V PS decoupling cap to 470uF/35V. Since I purchased lots of them for the Power supply mods, I figure, what's four more?. This will give the individual EQ sections a 5 times bigger reservoir of electrons from which to draw locally, and may reduce any power supply interaction between sections.
2. There is no high-frequency, or for that matter, low frequency local power supply bypassing on the +/-12V rails for the TL072 opamps on the EQ PCB's. There is an overabundance of 0.1uF caps on the power supply boards, where they do almost no good, due to the large electrolytics ensuring regulator stability. The 0.1uF caps on the power supply are totally ineffective in bypassing the opamps in the circuitry due to the inductance of the many inches of trace/wires that are between the power supply and the opamps. I tacked 0.1uF power supply decoupling caps to the bottom of each EQ card close to the opamps. There are a couple of close-by pads that can be used for that purpose.
3. As I mentioned before, the clip indicators employ a half-wave rectifier so that they only correctly indicate on Sine waves. Asymmetrical waveforms (music or speech) may or may not indicate correctly depending on the shape of the waveform, since the peak light only sees the positive half of the waveform.
The peak circuitry is present in the clone preamps, but not on the Neve circuitry. The input Z of the clip indicator circuit is 100K on the EQ cards, which should not cause any issues. On the preamp card, however, the input Z is 10K due to 1R62 being 10K instead of 100K. This somewhat low impedance acts as an additional load to the 22uF preamp output cap (1C13) which also is loaded by 51K (1R26) and either the input Z of the output amplifier (5K) or the much higher input Z of the "Filter" first EQ section, depending on the position of the EQ in/out switch. For that reason, I suggest that IC13 be replace with a 100uF cap. You can use one of the 100uF caps removed from Power supply decoupling duty that got replaced in item 1 above. I would also recommend changing 1R62 to 100K like all the rest of the clip lights.
Whether or not to increase the size of the coupling capacitors in certain locations of the ACMP preamps is a dilemma.
In these preamps, there are coupling caps between each EQ stage that roll off the low frequencies a little bit more as the signal passes through each section. The result of these successive rolloffs is significant low and low mid phase shift. A 20 Hz square wave will have huge tilt. If I were modifying these for one of my regular clients who wanted "better audio", I would probably significantly increase the size of the coupling caps over what Neve (and the clone) used. The resulting sonics would be a subjectively less compressed sound, and a smoother, more extended bottom, and better low-mid resolution. In that way, it would affect the Neve-original "color", which may not be wanted since these preamps are "color" preamps. As a matter of fact, almost every British-designed piece of gear that I have ever seen uses coupling capacitors that are way smaller than one should use if you care about maintaining waveform fidelity to frequencies lower than 100 Hz.
So unless I receive instructions from someone wanting more extended bottom end on their particular preamp, I am planning to restrict my capacitor changes to those capacitors that have become low-frequency "bottlenecks" due to the ACMP clone implementation of the Neve-like circuitry. As an example, the very low impedance 5K load of the class A output stage was never in the 81. Neither was the 10K load from the clipping indicator circuitry. As a result, this 22uF (1C13) will be too small to deliver the same low frequency response that was in the Neve. This one in my opinion should really be changed because it compromizes the sound of the preamp when the EQ is bypassed.
For those of you who have sent me your preamps already and are patiently waiting for me to return them, I hope you will understand that I want to do as complete a fix as possible the first time, so I am working hard to have a complete list of fixes so you are happy. Thanks for your patience.
