Audioforge
Did you get the buzz in the mid and upper mid bands of EQ ? This is a different noise that is
usually found after the transistor replacement. Then again your on 220V power so you may not
have the same problem as those running on 115V
To confirm your findings, I'll probably need to use a step up power trafo from 115V to 220V and switch my 81 mains power supply switch (red switch on back of 81) from 115V to 220V on back ( swap out fuses as well - 100ma type for 220V mains) and test to see if the buzz disappears.
audioforge said:
add a 600R on a switch at the back of the output TX.
remove the input capacitor on the line TX.
can you give reference to the PCB pad locations from above quote ( example r43, 1c21 ) so its easy to follow your modifications. Would like to try them out.
those 2N5320/21 NPN and 2N5322/23 PNP parts are somewhat pricey, but this category of transistor is higher current rated , hence the price. Here is another sub 2N5681/82 NPN and 2N5679/80 PNP both 1amp rated/100-120V/hfe 40-150 (TO-39)
and another TIP110/112 NPN and TIP115/117 PNP (TO-220 case,
observe BCE leg orientation) 2amp rated/60-100V/hfe 500-1000 with high power dissipation around 50W, this will last forever compared to the 10W T0-39 types and can be remotely wired with short leads from the PCB and heatsinked to the case with proper insulator. In fact it shoud'nt need a heatsink at all since it can handle much higher power.
The 2N2907A, 2N2222A ( T0-18 metal case) power dissipation capability is just marginally rated over the BC547,557 (TO-92 plastic case) parts pending replacement in the ACMP 81. This is why they still run hot. I think around 600-800mw as compared to the 10w rating of the BC441/461 and 2n5321/5322 (T0-39 metal case) variety .
