diyfanatic
keep us posted.
ooohhh you can count on that! ;D
keep us posted.
what do you plan to do, change the value of caps or change the psu?the PSU mods
mitsos said:2. Has anyone tried swapping the preamp transistors for MPS-A18s or similar? Should be a bit cleaner than the BC184c...mine has entirely too much "haze."
I have not been happy with the noise in the preamp at high gain. I bought 100 each of the MPSA18, BC550 and more BC184C's, thinking I could hand select lowest noise transistors for the first preamp stage. I tried 3 or 4 of each, without any notable difference when listening, so I gave up on it. Do you think this or any other mod might be worth pursuing to lower the noise?
diyfanatic said:- I find the reason why I have 3 inductors...I've 2 board 4!!!! ??? fµck...
mitsos said:solved my little buzzz issue. I posted that it mostly went away when I screwed the top on, but it would happen with a mic plugged (or dummy load) whenever I would go near the gain knob. If I touched the mic/xlr/some part of the case with my other hand, it would be silent....Last night I had an idea.... Too much paint (fancy that!).
