Hi, I need help troubleshooting this power amp. (Acoustic 450 Amp Head)
I received it in a non working condition after being plugged into a 230V instead of a 120V mains (with the power transformer wired for 120V).
The main filter cap (C505) and the bridge rectifier were shorted and I replaced them with new ones.
Two of the power transistors (480037 / 2N3773) were faulty and replaced all of the output transistors with new 2N3773G transistors.
The driver transistors Q4 and Q5 were also faulty and replaced with a pair of 2N5320 and 2N5322.
The preamp section seems to work fine and I'm getting a healthy signal at R401.
What is happening now is that as soon as I connect the output transistors (with no speaker load connected) both drivers burn.
I took voltage reading with the amp connected to a 100W bulb limiter and without the output transistors (my reading in green).
The largest differences between my measurements to the schematic was at the collector of Q404 (8V on my unit vs o 0.6V at the schematic)
And on Q1 collector (2.5V on my unit vs. 27V at the schematic).
What can make those large differences?
What else can make the drivers to get burn so fast?
