R4 measures 0.63V but is slowly dropping.
10mv DC on the output and is slowly rising.
C6 seems fine. I desoldered it and tested it measures 100pf.
*measured without load
OK, that seems like it might be working. The voltages will change slightly as things warm up but should stabilise after a few minutes. I'd expect Q3 to get warm, but not too hot to touch (like 70 C or more).
If the power supply caps are literally 50 years old that could certainly cause hum due to poor smoothing of the supply rails.
The light bulb is good for starting a suspect amp with no load, but if you attach a load, that light bulb might light up as the current is going in and the current is going out,
I use a light bulb for my winding machine, if you grab the chuck, the light bulb will light up and decrease power to the stopped motor, its kind of like having a clutch on the machine,,
