[quote author="mediatechnology"]OK, I'm pretty sure that I have an older Analog Devices data catalog that would have these. Let me look for them. Didn't realize that they re-used part numbers...[/quote]
Yes, I wonder whose decision that was. It does make things very confusing.
They were quite high on their discretes during that period (circa 1973 btw), with the typical our excreta don't stink attitude of AD of the period. Before I began to understand how FETs really worked I bought it too---there's an embarrassing gush I penned in the middle of an NSF proposal for a silicon target vidicon areal photometer where I extol the supposed virtues of the AD840 for a preamp. I also talk about the configuration of using half of it as an active drain load (less commonly seen than the source follower configuration, with half as the lower current sink) and make the very wrong assertion that it only has the voltage noise of a single device
![Oops! :oops: :oops:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Well, we didn't get the money, not because of that blunder, but mostly because of political naïveté. But it was probably as well, since not too long after a sharp guy did a really good analysis, supported by experiment, of how truly lousy the vidicon was---that its readout noise was horribly worse than almost any preamp's*. By then a stopgap instrument was underway using a linear photodiode array. When that system was finally working guess what?---the intrinsic detector noise was again much larger than the preamp's. See a pattern? But I had fun, learned a lot, and some science was finally done.
*When I met the outspoken Andy Young at Table Mountain Observatory, I mentioned a paper of his about the vidicon photometry from one of the Mariner missions to Mars, in which he compares the quality unfavorably to some stellar photometry with gas-filled photodiodes in 1914. He laughed and said "Ahh that's the paper that got me fired from JPL!!"
One of the problems was that the innards of the vidicons got perturbed inelastically on takeoff, which screwed up the lab calibrations; another was spacecraft system noise from power supplies that hadn't been adequately suppressed; and then the science team needed to show the public pretty pictures, and not do recalibrations.
