musika
Hello,
I'm most of the way through this modification to quiet down my ADA MP-1 pre-amp and I have a couple questions.
Is the TL072 chip that they specify need to be the TL072IN High-Temperature/Low-Noise Op-amp?
Or can I substitute another? They are not readily available.
Also, there are 2 12AX7's and they have plastic bases.
Should I take the time to upgrade to ceramic bases from plastic for these tubes?
http://www.scribd.com/doc/99237537/ADA-MP-1-Noise-Mod-Doc#scribd
