I wonder what REWs spectrum/fft with 192khz sampling would reveal in your common or garden walwart output , probably spikey as a porcupine .
Would it make sense to add a filter at the psu end ,so the spikes never travel down the cable , or would a common mode inductor be better served up at the far end so it stands a chance of balancing out anything picked up in the cable from external sources as well ?
Ive definately seen the interactions Abbey talks about between different switcher supplies in guitar pedal rigs where nowadays its common to find multiple Smp's with different pedals ,sometimes with different voltages . Ive noticed quite a high failure rate in stomp boxes operated in this way , and also chances of interference are bigger , typically you get big bunch of 50hz splattered with buzz saw harmonics . I did take a look at someones pedal tray one time who had a particularly bad noise problem, was three supplies , one 18volt smp, reg'd down to 9 volts rails to run Boss style pedals ,then another specialist pedal switcher 20 volts rail , individually each pedal worked cleanly , but by the time you patched all the pedals up and formed small ground loops all over the place S/N had degraded to about 20db , and the guy actually played like that for years ,he still had his sound ,noise was like a foghorn in the backround though .
