I have two V672-1 preamps.
Since they have only one output I would like to add a second output using a buffer circuit that can work on the +24V supply (without make any impact on the original output signal) and split the output so the transformer balanced output will feed the audio converters of the DAW and the buffered output will feed a standard headphones amp.
I don't sure if it will be better to use a op amp with a single supply or use a transistor buffer circuit?
Maybe someone have an experience with this kind of a circuit that can work good for this application?
