I just fired up a pair of 1540 eq's I recently bought, and they seems to work just fine, great! I then recapped them with a definite improvement.
I then thought I should check the amount of DC offset running into the output transformer and I measured that one gets - 2,1 mV and the other gets 0,7mV. Under 1,0mV seems to be regarded as just fine to send into a output transformer, without using a coupling capacitor blocking dc. So what to do with the one getting - 2,1mV?
Questions;
- Is -2,1mV fine into this transformer (original ADM output trannies) or should I try to adjust the circuit to get below 1,0mV?
- Does anybody know what values to use if I want to implement the circuit in the 1540 schematic to adjust for high DC offset and get it closer to zero (components R81 to R84 in the schematic, those are not specified anywhere in the schem as far as I can see)?
Questions;
