Center Tap Full Wave Rectifier - CT tied to DC instead of ground
Pat Maki
GDIY Supporter
Austin, TX
I'm repairing an Altec 525 power supply as a means to learn more about tube mic circuits. All the reading I've done on CT full wave rectifiers show the CT going to ground. Can someone please explain why the CT of the top secondary is referenced to 260V of rectified DC from the other secondary in this circuit? Why doesn't the CT just go to ground?
    489.5 KB
There is a limited permissible cathode to heater voltage, data sheet might indicate it…the cathode is at 200vdc in this schematic/cathode follower configuration…in a typical plate follower the cathode will be close to 0vdc and filament supply can be referenced to 0v
Thanks @shabtek. 5840 data sheet says cathode to heater voltage max is 200v. I think I get it, so it's relative voltage between the two. Since the heater voltage is elevated to ~260v and the cathode is at 200v, then the cathode to heater voltage is 60v and well below the 200v max. Is that the correct analysis?
And thanks for pointing out this is a cathode follower. Most of my reading on tube circuits til now has been on plate follower....apparently. The cathode follower config is blowing my mind open a bit right now..will do some deep diving here to get an understanding of how it works. From my initial reading this morning, that definitely helps me understand some things that were confusing when I presumed this was a plate follower...Thx!
Look up heater elevation... elevating heaters....
I pretty much always do it.... Feels like a cheat code for noise most of the time...
Thanks @scott2000 . Love Blueglow's vid's but hadn't seen this one. Very helpful. Sounds like the purpose of elevating the heater voltage is reduce noise in the circuit.
I guess I'm still not clear on why the center tap of the top secondary ties to 260v DC from the secondary...wouldn't that send AC from the CT of the top secondary into the circuit and/or send the 260vdc into the pre-rectified AC in the top secondary? Sorry, newb here....just trying to get my head around this...
I believe the reason is more along the lines of what shabtek posted but noise is more often than not a benefit imo... maybe why it's used where it doesn't necessarily need to be.
interesting question. Not sure . Guess any ac after rectification is being shunted to ground...filtered out
the ac is rectified? That's how it's dc
Using dc as a ground reference is unclear to me how that works as it relates to transformer winds... Like I said, interesting question..Not sure..lol
Gotcha.
To try to get a handle on this, I've highlighted the current flow on the positive half of the AC cycle, with green dotted line being flow from trafo to load (heater) and red dotted line being the return path from load (heater) back to trafo (by way of the center tap). I also added the voltage readings (to chassis ground) at both sides of the heater to see how they relate to the other voltages. It certainly seems as this design is using the 261vdc that comes from the bottom secondary as ground reference since that path is 5vdc lower than the path from the trafo to the heater. So, it's using the relative difference in voltage potential (266v-261v=5v) to drive the heater. Would love to hear one of the fine experts here confirm or deny this assumption.
If that assumption is correct, then setting the heater return path/ground reference to 261v would also satisfy the limited permissible cathode to heater voltage that @shabtek refers to above. (Heater @ 261v - Cathode @ 200v = 61v)....which is well below the cathode to heater limit as cited in the 5840 tube data sheet (200v).
I'm still a bit baffled by how the DC can be fed into the CT (which is AC no?)....but maybe one of the good folks here can elucidate on this as well.
    598.6 KB
Well, you CAN also measure that directly, y'know...
That is indeed true.
Nothing necessarily gets "fed into" the center-tap as such. In a normal full-wave rectifier arrangement, that center-tap would be connected to ground.
Keep in mind, a transformer winding is fully "floating" (galvanically isolated) from all the other windings, so you can connect the "reference" of that winding wherever you want. In this case, the "ground" of the heater supply is merely "sitting on top of" (ie. its own "0V" reference is) that 260V-ish point.
Yes, I understand this...but this wasn't enough since I'm learning and needed to get a more comprehensive understanding of voltages around the circuit.
Thanks for confirming!
Thanks for confirming @Khron . This is clear now.
Looking at things closer, it is an odd duck. Can't make out 100% the elevation circuit and I've never even seen a single phase rectifier used before...
Awesome.... Hopefully someone can clear things up
for your reference, here's the entire circuit (w/notes)
    425.5 KB
