ADR Rack Power Supply - need help on defining output connections
musika
Minneapolis
Hello,
I could use some help defining output connections on my ADR Power Supply.  Top cover I think has this labeling, which did not come with my unit.  Does anyone have schematics that would show this, or can someone please tell me which screw terminals are +28v, -28v, 0v, 48V , Ground??
    319.9 KB
Well I did measure, but shows 0V across the board. I thought I was missing something. All the fuses seem Ok when continuity tested.
Fuses can be fine if there is no power going through them ;-)  LEDs may or may not indicate what is going on.  You need to trace voltages in and out of the transformer, then through the diodes/rectifier bridges, regulators, etc.
Thanks for all the replies.
I did notice a ~350mA reading on the one terminal second from right.  I'm not sure I can do the tracing, but if I had the layout, I could get some help.
Does anyone have the schematics for this power supply?  I'm not even sure if there is any model number.... just ' rack mounted ADR Scamp Power Supply '.
I've searched forums / the internet and haven't come up with much about this unit.
I found and posted some Scamp power supply information into the technical documents section. I am not sure if it directly applies to your power supply but it may help.
http://groupdiy.com/index.php?topic=56151.0
This is great!  A little hard to read though.  I see some of the same part numbers.
Could you please email me a higher resolution of this documentation.
I tried to download from that website before without success.
[email protected]
