AndreasSchwarz said:from the web:
http://audiophool.com/Misc/6AU6%20grounded%20plate.pdf
That's the one I was thinking of.
ian
That's it.untune said:I think I found the schematic you were referring to, I've attached it and I've also tried to incorporate it into the first stage of my pre (on the right.)
This method is fine for the first stage. The second stage can tie anode, suppressor and screen grids together and run at a higher current. I seem to remember I used something like 390 ohms in the cathode and 39K in the anode.I'm just reusing component values but I'm wondering if I have the right idea. From what I've read, this method of triode operation (supressor + plate to ground, screen as anode) will be ideal for a lower signal levels, i.e. the input stage (~100mV signals from mic and attenuated line). Please correct me if the alternative (screen, suppressor and plate strapped) would be better - research has pointed towards that being more suited to slightly larger signal (1V+) and may therefore be ideal for the second 6AU6 triode. Any comments are greatly appreciated![]()
Should make little difference. Notcie how the BBC rpeamp runs at a very low current and uses a large HT dropper and smoothing cap for the first stage to minimise HT hum. The first stage is where you really need to keep out the humAnother couple of questions that have come up... regards to the power supply filtering, I'm sticking to a 20uf reservoir for the rectifier, and I can make the other three (C1, C10 and C11 on the last schematic I posted) either 40uF or 50uF (no 47uF's available) . Or I could make the first smoothing cap after the choke a 40, and the other two further away from the PS 50's. Is there any advantage to either or is it a moot point?
This is a common technique used to elevate the heaters a few volts dc above 0V. This has the effect of reverse biasing the diode formed by the heater element and the cathode which reduces the induction of heater ac voltage onto the cathode.Lastly, something I only just noticed from the original schematic that I missed when redrawing - both of the heater taps on the power transformer (5.7V and 6.3V) run to a point marked 'X' - i.e. are connected to the cathode of the 6BQ5 valve. What is the purpose of this?
Cheers!
Lee
ruffrecords said:This method is fine for the first stage. The second stage can tie anode, suppressor and screen grids together and run at a higher current. I seem to remember I used something like 390 ohms in the cathode and 39K in the anode.
Should make little difference. Notice how the BBC preamp runs at a very low current and uses a large HT dropper and smoothing cap for the first stage to minimise HT hum. The first stage is where you really need to keep out the hum
untune said:A more logical question - PRR spoke of a resistance loaded triode EL84. It's my understanding that the OT acts as a plate load in a regular SE output stage, but how do I apply that resistance - have I got the right idea with a resistor in series with anode and screen connected? There unfortunately doesn't seem to be alot of information out there on it
Cheers!
Lee
