Thank you Jakob!
ln76d said:
Are you sure it's not expected to do this?
That's good question
I really don't know, last time when i use c414, it was good few years ago so i don't remember.
If there's someone on forum, who can check switching in his C414, i'll be appreciate for any info!!
ln76d said:
This can be seen in the right light, at the right angle.
Really, i don't understand what you mean?
ln76d said:
What frequency did you e.g. tune the membrane to?
I didn't tune it at all, i really don't know how to do that with no option for any adjustment. Changing those plastic shims?
For first look those plastic shims looks identical. Ofcourse this can be micron difference.
Maybe i'm wrong, but i always thought, that this design of capsule was dictated by economic factor. Lower quality but cheaper, with simplified servicing, reducing most of all hard to made adjustments.
Looking on developement production of dynamic microphones capsules, i think it can be most deciding factor.
Just compare akg d12 capsule with capsule in d112 and what's more important compare the sound of both.
It's there any existing source of information about adjustments on teflon CK12?
In case disappearing sound.
Why only on switching from omnidirectional to cardiod?
This shouldn't be also on changing from hyper (or super) cardiod to figure eight?
Work on different types of polar pattern don't charges different values of current?
Maybe one of transistors is on way to die?
I'll try with second, unfortunately used, capsule, which looks like originaly no touched, serviced etc.
My only problem is juggling on those capsules, because i don't want to mechanically damage them.
