AKG Perception 420 Mod
Audio Freq,
When the front side no longer works properly, you swap it with the back side which is less often used (as a quick, emergency fix), then ask for the help of someone experienced in cleaning capsules. I have seen very dirty capsules that were still working. Indeed, dirt increases the mass of the diaphragm and slows down the speed of response to transients, so in many situations SDCs are preferred. But for now your capsule should be working properly.
Audio Freq,
That is wild. I always just sank my capsules very lightly inside alcohol and distilled water mixed solution, let the stuff dissolve and fall off the capsule, and then air dry it. I haven't had any bad luck or anything. I seen some people use q tips or light brushes, but i never been comfortable rubbing anything on the mylar. I always just let the water and alcohol work its magic.
I know we were all being sarcastic just recently, but are you being serious or sarcastic? Wouldn't the smudge, especially if its some sort of chemical or adhesive, be a detriment to the mobility/function?
No, im serious. But are you talking just about the part i marked with red, or is the part marked with yellow some dirt, or just reflection? Yes, i would also move that termination a bit away from the diaphragm, that solder seems too close.
    595.1 KB
Some capsules have a very small hole (the size of a needle tip) in the diaphragm, hardly visible, in the area not covered with gold, to release the pressure. If liquid enters between the diaphragm and the backplate, at this high impedance, you compromise the capsule.
The yellow mark, its like a smudge of something. Im not sure what it is. I don't think its a finger print, it looks more like flux or glue or something? Idk.
I always let it dry inside and out before I re-install the capsule. I disassemble the two halfs, to let the water vapors escape.
I don't think it's a big deal, but since it's a new capsule it shouldn't have any of these issues. I'd either ask for a refund or replacement.
Audio Freq
Try to buy some 2SK30A through the Black Market on our group, maybe someone kind enough has some suitable parts available.
There are members who even bought 1000's of jFETs to choose the best ones.
I think this is a great learning opportunity for me. When selecting the best JFETS, what measurements should I learn how to take? I have a multimeter, and a beginner oscilloscope. Would these be good enough?
Well I think its too late now, since I already installed it into the mic, but thank you.
