smallbutfine
Hi guys,
I took a look on an AKM4393 based DAC i have around here and would like to use a transformer on the output.
Since I have some LL1539 around, I now wonder if I can hook up the transformer directly to the converter chip's outputs (passive design)?
From the datasheets, the AKM outputs max. +-2.55 Vpp and has an output current of 3.5mA, load resistence 600Ohms.
The LL1539 +31 dBU balanced driver transformer could be used in a 1:1 instead of 2:1+1 configuration.
(Going unbalanced to my unbalanced amp for monitoring.)
Is there a serious flaw here? would I be forced to have an active buffer?
Kind regards and thanks in advance
Martin
Martin
