Gold said:
My point is that a test can be designed to confirm bias. Whatever that bias is.
well controlled double blind listening tests with enough trials to realize statistical significance can determine if there are actual audible differences or not. The double-blinding thwarts expectation bias.
Like Abbey said if you use a resistive load everything will measure great.
not always... but most modern amplifiers are very good.
Try driving a difficult load in the real world. Not so much.
I spent decades doing exactly that... You should have seen the "difficult" loads that Jack Sondermeyer (RIP) used on his test bench when checking out amplifiers. He released the magic smoke from inside more than one competitor's amplifier doing stress testing.
Only listening tests will tell you that.
I am far less optimistic about listening tests. I only know with any certainty what I can't hear. I can measure differences that I can not hear, I never heard a difference I couldn't measure, while some transient events are more difficult. (I rolled a custom variable tone burst generator to help parse out transient artifacts).
As I already shared I went to lengths in that amplifier test last century to load the amplifiers with actual loudspeakers (IIRC I may have loaded them in parallel down to 2 ohms nominal for some of the trials), and then cranked them up loud. If you think you can hear subtle differences between big amps driving sound reinforcement speakers at high volume, you are a better man than I...
I performed my critical listening to the null signal in a relatively quiet room nearby... The sound proof room wasn't completely soundproof but adequate.
In my experience if we determine that there is a difference, we can then dig deeper on the test bench to quantify what that difference is. If you can measure it you can manage it and design out any such flaws. Indeed inappropriate current limiting can be audible and I suspect one of the accidental benefits of the popular early (Hitachi) lateral mosfet amplifiers, is that some of the amp designers punted on using any current limiting at all because lateral mosfets enjoyed a positive tempco preventing thermal runaway. Further the lateral mosfets had high gate capacitance that could compromise marginal drive current in output stage drivers. This softer high end, and lack of current limiting may have sounded better than mediocre bipolar amp designs of the day.
Likewise some inexperienced exotic loudspeaker designers could be optimistic about amplifier drive capability. At Peavey since we designed both loudspeakers and amplifiers it was hard to ignore that interaction. We would hear quickly about any mistakes we made from the dealers/customers.
