Altec 1612a - No Output on meter and no sound? Help
The mind
I picked up an old Altec 1612a and am trying to revive it. The first 1588b preamp I got had a broken guide pin, and I didn't realize this until I turned the unit on. If it was in the wrong orientation could it have caused a voltage spike that messed up some components in the output section?
I bought a working preamp for the socket that now has a proper guide pin. It's now showing gain reduction when I speak into mic, but there is no sound output when I flip the meter to output.
Any ideas how I can troubleshoot this? Here's some pics of the inside.
  • IMAGE 2024-02-21 20:38:37.jpg
    156.9 KB
  • IMAGE 2024-02-21 20:38:51.jpg
    187 KB
We would need way more information to help you with this. Things like:
-what, if any, test equipment do you have?
-did the unit ever work for you, or did you acquire it in non-working condition?
-what is your troubleshooting experience / skill level?
-and so on...
I'm afraid this is way beyond a "If it doesn't work, do this!" kind of fix.
-and so on...
I have a multimeter. I'd say I'm intermediate at fixing stuff. If I know what component is messed up I can remove and replace. I'm just not super good at diagnosing the problems. It worked when I got it, but when swapping the preamp socket I think I inadvertently ****** up the voltage because the socuket pin was broken, so I think I plugged it in where it sent some voltage down the wrong path. I was getting output before that. So I'm sure I fried something. Nothing appears fried from looking at it.
The vu on the input registers so I guess the signal is making it through the circuit partially. Any suggestions?
