college101
Ok..I am back! Its been a while since my last post. Im finishing up my last class for my associates degree in Electrical Engineering. Right now I am in an Advanced AC class, and im having a blast in it. I also recently passed the CETa exam....
So for my class project, I decided to build a P2P turret board 436C. Hammond PT,-Sowter input and output, some RCA tubes- did the darn thing right. I got an "A" on the project and my teacher is pretty impressed with it.
I have completed my burn in period, and want to make sure I have it biased correctly. I followed the original spec's in the widely passed around 436C manual online. There were only two small changes I made to the circuit, which I dont really count as "mods" -Which some people do for some other reason than I know.
1) I installed a 100 ohm adjustable pot in R8's place to help ensure I have the correct voltage across the honeywell VU meter I installed.**I know , i know- I couldn't get to a real Altec meter and had to pull the trigger with this one...
2) I replaced R13 Power Supply resistor with a 3 watt over a 1 watt... Its the little things right guys?
So, now I was expecting to be able to tune my voltage across the meter and get it to sit at idle, with the meter reading at zero, but right now,its around minus 20
BUT, if I play with the controls, varying voltage and input,threshold, and release, I can move the needle around...but this is with no input signal and the compressor at idle....
Some helpful responses could get me going in the right direction! Thanks College101
