Going through some of the amps and looking at a couple of these unregulated PSU's.
complete manual:
https://groupdiy.com/threads/altec.44774/page-2#post-1041174
I appreciate the reality factor of a tapped primary adjustment to cover a 2 to 1 range of loads, to be sure filament voltage is correct for the number of amps used, with the note that B+ "should fall in the range of 250-300V, the exact value is not critical".
The use of a circuit breaker rather than a fuse is curious; why not a fuse?
I don't immediately see anything on the market now that is the same as this one:
Type A, 2.5A operate, 3.5A break
complete manual:
