Alternative rocker or flick switch to replace rotary one
jackinthebox
Member
Hi Guys,
not sure if this is exactly the right place for this question, but I'm looking for an alternative to this switch:
http://www.mouser.co.uk/Search/ProductDetail.aspx?R=A11405RNZQvirtualkey61170000virtualkey611-A11405RNZQ
it's a non shorting SPST, rotary, 2 position, 1 deck, 1 pole switch with a 2.5A 125VDC/AC rating. I had problems with the rotary one being rotated too far by clients and thought a rocker or flick-switch would be a more robust solution.
I'm guessing it's an on/on switch, but this is not included in the description on mouser.
Thanks in advance for any thoughts!
Jack
The datasheet linked to on the Mouser page confirms it is single pole 2 position i.e. On-On.
So a rocker or toggle switch will work fine.
