Welp, got a replacement output transformer -- pn#C-050438... Supposed to be the original replacement part for a F@nder HotRod Deluxe amp. The guy I got it from actually designed some of the Sunn and Amp@g stuff, needless to say I was pretty siked I was able to grab his ear for a few minutes!
I'm gonna try to wire it up within the next day or two, but I got more questions first! There are 7 wires coming out of the original transformer... It has the two secondaries (black and yellow) fed out to the speaker... A red wire going to the power supply, an additional black going to ground, the blue and brown going to the tubes push pull style... And a green wire terminating at a resistor (in the schematic it looks to be coming from the secondary side of the tranny)-- what is this for? There doesn't appear to be multiple outs for 4ohm vs 8ohm operation or anything (the speaker is an 8ohm load BTW).
By comparison, my replacement has red, blue, brown on the primaries (which look to mimic the original wiring from what I could find online about F@nder trannies), a black (which I'll have to run out to ground and back down to the speaker), a green (supposedly 4ohm) and a green w/yellow (supposedly 8ohm)...
First off, I've found differing reports as to which is the 4 vs. 8ohm connection, anyone know for sure? Second -- can anyone tell what the green wire going out to that resistor does, and if I can simply leave it out?
Thanks for all the help in this thread,
Tim
