AMEK BC2 help
Soundpsychologist
New member
Lansing MI
Hey guys!
I received a BC2 from my friend this past weekend, but it looks like I only have 1135 busses, which are mono..
Is there any way to configure the two mono busses to get stereo out? Or would someone swap both for one 1136 strip?
    2.4 MB
What happens when you PAN one channel completely to the Left?
Does the signal goes into both 1135 busses or just into one of them?
And when you PAN a channel completely to the Right?
So the right 1135 I can use a jumper to set if it is summing the right or left stereo channel, the left 1135 I have not gotten any audio from yet..
If I pan it away from the assigned Left or right, it’s just silent.
If I remember correctly the 2x 1135 used together will make a master bus.
Maybe you have to repair the second 1135.
As I remember one 1135 would receive the left summing, if panned Center both 1135 will receive the signal, and if panned right the other 1135 would receive the signal. Then the 1135 faders would work as independent L and R Master faders
