Hello guys,
I have recently built the ez1073 module. Everything went smooth and after powering it, I could adjust the bias voltage to 90mV as well as per the instructions. But the unit is not passing any signal. 48v led is turning on, the relay clicks as well. But I am getting no output from it.
Is there's any particular place I should look at while troubleshooting?
Any help will be very much appreciated.
Thank you
Thank you
