I would use thinner traces in order to decrease parasitic capacitance and increase clearance.bluesbaz said:I am in love with the Ampex 351 but not its size. I would like to sell mine off and make some smaller clones.
Here is my design. Thoughts?
I don't agree. A ground plane is trouble only if it allows ground currents from output stages or unregulated supply currents to interfere with low level currents. A static shield ground pour, connected to the reference ground is good design practice for tube stuff. Some care must be exerted in order to minimize parasitic capacitance in very hi-Z areas, though.rlaury said:I'd do away with the ground plane all together. Nothing but trouble.
No. Definitely wrong. That's the unfamous abuse of the star ground concept. Proceeding that way makes each stage have a different reference. Proper arrangement is hierarchical ground or "ground-follows-signal". Indeed, in valve equipment, this is often invisible because the currents are typically much lower than SS circuits. Still, the principle is identical. there should not be different rules for tubes and SS.Use an individual ground per stage and tie those grounds to "0" volts at a single point.
craigmorris74 said:Don't know if this is helpful, but thought I'd share it anyway:
http://recordingwithgas.com/GAS_351_PCBs.html
