Brian Roth
The last picture shows a 350 electronics chassis.....dunno why the ad says 351! But very clean units.
Bri
Bri
[dunno why the ad says 351] -- Based upon how the ad is worded, I got the impression that the -- CASE -- is from a 351. Dunno.....The last picture shows a 350 electronics chassis.....dunno why the ad says 351! But very clean units.
Bri
Well for all intents and purposes, the transports were identical. The electronics units of the 350 and 351 appear identical from the front with one tiny difference. The 351 panel has a small "dot" engraved below the small "input transfer" switch directly beneath the VU meter. Ampex did that because production of 350 and 351 overlapped and they wanted to make it easy to track inventory at a glance in the warehouse.[dunno why the ad says 351] -- Based upon how the ad is worded, I got the impression that the -- CASE -- is from a 351. Dunno.....
I'm eager to know what the project is about that the sound of 1950s tape is so integral. I'm sure it has been suggested that using tape emulation plugins would be much more convenient, although not exactly authentic...
Exactly my thought.I don't really see the reason of hauling an old tape machine all over the planet...
I would record everything digital, no processing, and at the final stage, at one location, record all those files to the tapemachine for it's imparted sound.
I use an old (all original tubes) G36 as an effect, but record to my DAW first, this way I can do several runs on several levels and listen wich take hit the tape saturation just perfect and record that back into the DAW.
The film is set in WWII and uses some vintage audio interviews recorded in the period after the war from 1946 to about 1960.I'm eager to know what the project is about that the sound of 1950s tape is so integral. I'm sure it has been suggested that using tape emulation plugins would be much more convenient, although not exactly authentic...
Thanks. We're looking for studios that have a tape machine. If this doesn'y exist, traveling with one fits in somewhere among plan B, C, and D, as does the approach that you suggest.I don't really see the reason of hauling an old tape machine all over the planet...
Thank you for your kind words. My thought is that RCA ribbons and Neumann/Telefunken tube condensers connected as directly as possible into a vintage tape machine will have a vintage sound (rather than a possible vintage-ish sound).Thank you for the insight into your project. That's exciting. And I applaud your choice to be authentic.
Thank you. Yes, road cases could be checked out. Traveling with a tape machine is somewhere among plan B, C, an D. I'd prefer not to travel with one as I will either be traveling with one colleague or solo. My goal is to find studios near the voice actors that already have a vintage tube tape machine in active use and biased for the tape that they use. We will do this project in perhaps 6-12 months. If we end up having to travel with a tape deck, I will definately refer back to your post, services, and will likely check in about any tape you have available at the time. Right now, the focus is on finding studios that have vintage tape machines in active use, Thanks again.[I looked at the 351 in road cases] -- There are companies such as GATOR Cases, SKB, Pelican and a few dozen others that make heavy-duty road-cases for concert sound-reinforcement companies. These cases are specifically designed and built for the rigors of travelling and the abuse of stage-crews!!! I am more than certain that you will be able to find a set of road-cases to fit whatever AMPEX tape-transport and its electronics you end up with.
From there, should you need any additional assistance in coming up with a "cohesive" cable-assembly harness and/or custom I/O rack-panels or any other sheet-metal design-work to complete your "On-The-Road" system, I can help you out with that.....as that is what I do!!!
In addition, I even -- STILL HAVE -- a case of "NEW-IN-THE-BOX / STILL-IN-SHRINKWRAP" AMPEX-642 7" reels of tape!!! And, if I can remember correctly, I think there's also about 6 or so 10-1/2" pancakes of the AMPEX-642, too!!!
Interested???
Thank you. I knew about the Ampex and Studer plug-ins but not this rack-mounted emulator. An interesting device. I had come across this company making tube preamps that they developed to sound like Ampex preamps https://www.electricandcompany.com/ec3 .Then.....there is this:
The ATS-1 Analog Tape Simulator
The ATS-Analog Tape Simulator is the first product that uses the AnaMod process for modeling complex analog circuitry entirely in the analog domain. Specially developed analog building blocks are 'coded' to emulate the behavior of a complex analog system. Unlike digital plug-ins or processor-based outboard gear, there is no latency, and no A/D or D/A conversions to compromise the sound. The result is a faithful recreation of the original response, without using the original analog hardware.
All of the important features of a two-track analog tape machine are found in the ATS-1, including speed selection, bias, LF record and HF Repro EQ, and the option of adding tape hiss, if desired. The reference 'record' level, as indicated on the illuminated VU meters, can be adjusted from 0 to +12 dBu in 3 dB increments.
The ATS-1 accurately models the behavior of specific tape machines and tape formulations, and allows the user to select from up to four machine and tape types. Optional machine and tape types are available on easy-to-install SIMM cards. Standard tape formulation cards shipped with the ATS-1 are the GP9 and 456. Standard machine cards are the A800 and M79.
By popular demand, wow and flutter is not included.
Thank you! That's enticing. However, my goal is to find studios with a vintage tube tape deck in active use. Traveling with a deck is one of several back-up plans if I don't locate studios with a tube Ampex or Studer in active use by the time we do this in 6-12 months.
Unless you are C.W. Stoneking...
There's only one way to really get "that" sound.
Recorded on old vacuum tube tapemachine and two (ribbon?) mics in a room;
This took a whole lot of effort to get it "right"
