dawsonaudio
I am having trouble with the stop tension on my Ampex MM1100 2 inch/16 track machine. I've been trying to get some help for a week or two now over on the Ampex mailing, but haven't made much progress. Basically, I can normalize the reels, adjust the play tension, rewind and forward tension, but the stop/idle tension can't be achieved. The supply reel can be adjusted properly, but the take-up reel barely begins to add tension to the tape even after adjusting the stop trimmer pot all the way. I've tried adjusting the master gain trimmer on the transport control board, but this doesn't help. I've checked all the voltage/s at the power supply and they are on point.
I've been thinking of replacing all of the tantalum capacitors on the transport control board (like 5 or 6) of them. Not sure if one of those could be the culprit.
One other question, would electrolytic caps be able to substituted for tantalum caps in this situation? Not sure the answer to that.
Nate
Nate
