I've finish recaping an Ampex PR-10 (mono version with a mic preamp).
I replaced the filament selenium rectifier with a couple of 1N5408 diodes.
The original rectifier rated for 2.4A while the 1N5408 is rated for 3A, so it should be a good replacement.
The preamp working but with a very strong 100 Hz noise.
I've tried to replace tubes and the noise remains.
While I was looking at the filament output there is a 500 mV at 100Hz AC between the DC filament leads.
This is a normal behavior or I should expect to see a DC voltage with a little ripple?
