Nope nothing else going, at least with my units... I have spent months of time messing with the EZ1073. I've tested every single part of the circuit. I've changed every component several times. I've tried lots of different transformers. I've tried modified power supplies. I've tried super high end components. Tants, even tried electros at one point, NOS BC184C... And all at the same time while building my own etched units, as well as owning a AMS 1073 and AMS 1084.
I've studied these units to the point where I'm sick of them. I know all the techniques and wired schems used in the originals. The grounding scheme is very specific in the original schematic. If you pay close attention you will start finding the differences in how the EZ1073 is wired up as well as the 2 resistors that are off from original value, I am surprised nobody has spotted those yet...
From what I've learned so far, the biggest impact on the sound of a 10XX class A module is the output transformer with the DC flowing through the primary and the gap at the core that is 0.003. The tolerances I believe are +/-20% with the Carnhill output transformer and probably even worse back in the day. I believe this is the reason allot of people say no two 1073s ever sound alike, even the same issue number and build date... It's that massive chunky LO1166, go back to what Rupert said in Sound City... that pretty much sums it up.
Don't let someone say it's components. Every single channel on the SSL G Series I work on sounds exactly the same and there's thousands of components on each channel. Capacitors and resistors are made to such strict specs today that those aren't to blame when things don't sound right. Transformers, are another story.
If you don't wire that output transformer correctly you will start getting stuff that doesn't sound right. It wasn't until I bypassed as much as the PCB as I could I started hearing the EZ 1073 units like I've never heard them before. If even 1 little tiny trace on the board is too close to another trace that it doesn't like, problems start happening. I'm not gonna say the EZ1073 board is flawed but I will say from my own personal experience with the 2 boards that were sent to me, they sound better with what I did to them, and clearly measure better too.
Even still at the end of the day, my AMS 1073 has something magic to it that sounds even better than my AMS 1084
(witch retails for a nice $4,295.00) Yeah $,4,295 for a preamp/eq... Anyways the AMS1073, it has a harmonic sparkle thing in the high end that even my 1084 doesn't do. My home etch units don't do it and neither do both of my EZ1073s.
All the same components in everything. Witch again really leads me to believe that those output transformers are one of the hardest things in the world to get perfect and even harder since a EM***** spec sheet was never made for the 1166. Leads me to believe my AMS 1073 has a really special output transformer in it by luck, and every single unit measures the exact same for freq and dist. This just makes even more sense to me when people say "something else is going on" It's just the variances in the output transformer we are hearing. The input transformer is pretty neutral. And come on, when you're paying AMS prices for preamps, don't you think they should all have the magic sound?
Go look at Avedis MA5 and you will start understanding why he has a custom Jensen output transformer made to his exact specs that he designed. He could have just used that Carnhill PCB output transformer...
Anyways, to sum it up. Experiment and more importantly get on to making music. This Neve quest thing has put a huge dent in my creativity and music making, at the end of the day I'm a musician, not a electronics engineer and a year later almost I've took a big detour into Neve neverland and haven't made much music since. I have gained a ton of knowledge though, witch is cool.
Enjoy your EZ unit's, they sound pretty badass when they are wired properly, and that's not to say they aren't wired properly how they come in the kit.... Again I'm only speaking on my experiences and conclusions after messing with all this for so long.
