An interesting project?
Rochey
White Market Member
Dallas, TX - Formerly UK
http://www.behringer.com/FCA202/index.cfm?lang=ENG
a $100 firewire interface from behringer... I wonder if we can mod it? higher performance converters, better frontend...
the mind woggles at the thought :green:
It's probably ok, assuming the drivers are alright.
I'd imagine it will be almost entirely surface-mount making mods a bit of a no-no.
$100 is fairly cheap.
I got an M-A*udio Transit 24/96, 2 in 2 out USB interface which seems to do the job fine for £25.
Hmmm. I'm thinking about changing the decoupling capacitors.
we'll see, i think it's just a stereo box, although if it's either a bridgco or wavefront semiconductor device, i'm sure it could be opened up a little. :)
[quote author="gyraf"]I'm with you on this one Rocey - let's hope there's something upgradeable inside this time..
:razz:
Jakob E.[/quote]
Well... here have you one of these opened:
http://personal.telefonica.terra.es/web/turiae/MyPictures.html
(beware >2mb)
I have not tools to solder/unsolder surface mount components, but I'd like to tweak the box.
Suggestions? I have several Elna ros silmic 10uF to start with for the audio path.
What do you think?
Thanks all!
JL
oooohhhh :)
Now I'm a happy bunny...
So, those AD86xx devices look like opamps...
The Cirrus device is an AD converter.
That oxford semi device is a 2in8out device.
I'm trying to work out where the DAC is though... I think it's below the 10uF below that cirrus device.
Providing those clocks can be "understood" better converters could easily be patched in... with our own frontend :grin:
[quote author="Rochey"]
[/quote]
I have not a mag glass here to read the numbers on that chip (I'm getting old to see this little crap) :shock: ...but it seems to read 3450 d513. It is possible?
Regards.
JL
mmm unbalanced inputs... maybe a upgrade here is better than better ADC.
AD8604 - DigiTrim™ Quad Rail-to-Rail Input and Output Amplifier with Very Low Offset Voltage and Wide Bandwidths
http://www.analog.com/en/prod/0%2C2877%2CAD8604%2C00.html
AD8602 - DigiTrim™ Dual Rail-to-Rail Input and Output Amplifier with Very Low Offset Voltage and Wide Bandwidths
http://www.analog.com/en/prod/0%2C2877%2CAD8602%2C00.html
CS5340
101 dB, 192 kHz Stereo A/D Converter
http://www.cirrus.com/en/products/pro/detail/P1028.html
[quote author="ciminosound"]Just put a tube in it! :wink: :green:[/quote]
:wink:
yes, but liked to keep it small (I have other interfaces and the aim of that adventure was to get a very portable one).
