an LA2a is born :)
Supposedly the first Sovteks were pretty bad, but the latest ones are pretty good, at least in guitar amps.
I do not know when you bought yours, but they might be worth another listen. KCA sells them and tests them first.
cj
[quote author="Ethan"]I kept hearing very very low level intermittent crackling/hiss. [/quote]
Aha! I am currently having the same problem in my Marshall JCM 800 that I just retubed! I thought it was bias, so I did the adjustment, but I found that I still have the problem. I bought the tubes new from www.thetubestore.com so I didn't suspect them, but it couldn't hurt to swap out preamp tubes, I suppose.
Hmm. The LPS Sovteks have the spiral filaments, which are supposed to nix hum from an AC heating circuit. That wouldn't be a problem with DC heating, would it? Maybe just crappy, but you wonder.
I hear good things about the JJ's, and for stages not prone to microphonics, the current issue EI's are good. Can't afford NOS.
Bear
Hi, here did you find the chassis !!! Thank
[quote author="Scenaria"]This one is due to all of the effort of one of our very own... I'll give him props once im sure he is ok with it :)
fired up on the first shot... only problem was one of the 100k pots were defective...
next one will have metal film resistors..
[/quote] :roll: :?: :?:
I tried Sovteks in gtramps already a few times,
but they still don't do it for me... might be me, who knows?
I don't know if gtramps is similar to valvegear for recording/compression in terms of valvequality.
just my 0,02?
Tony
