I'm studying to gain a deeper understanding of phase in relation to audio frequencies. At the moment I'm trying to work out whether ALL eq has an effect on phase, or whether it depends on the implementation. In particular, I'm struggling to understand whether phase changes are introduced by running a complete stereo mix through 2 Pultec EQs.
Looking at the circuit, the entire waveform passes through the passive EQ circuit before amplification. AFAIK the EQ circuit doesn't split the signal and then recombine before the amplification stage, so it's hard for me to imagine how phase shift can be introduced here if the complete signal is always intact.
Is it useful to think of phase as a dimension that exists between two separate signal paths? So that when phase of one signal is considered, it is always in relation to another signal which is independent in time?
Stephen
Stephen
