- Joined
- Nov 22, 2023
- Messages
- 8
ELI5, please, why so many fancier mics use BJTs or JFETs instead of op-amps? I would think the op-amp is the right tool for amplification circuits. What is this aging EE forgetting?
That's... uh... that's it? #coughThey're cheaper.
I am one of those who agrees with that sentiment. ... not everyone does.I would think the op-amp is the right tool for amplification circuits.....
Also most famous mics that are copied over and over again use fets. Fancy op-amps that are suitable for mics (low current, low noise...) are relatively new thing.ELI5, please, why so many fancier mics use BJTs or JFETs instead of op-amps? I would think the op-amp is the right tool for amplification circuits. What is this aging EE forgetting?
They're cheaper.
With the (gradual) move towards 32 bit float recording, digital clipping will slowly become much less of a problem....... i wanted a condenser with it's capsule properties but with high headroom op-amp circuit, so I can get that transient into my DAW without any clipping. So i built one. I like the flexibility of dealing with these transients in post.
probably sounds like intermodulation distortion...Hmm... that makes me wonder what would happen if I played my electric guitar through an amp where I could control the slew rate limit independently of the usual kind of harmonic distortion. What does pure slew-rate-limited distortion sound like?
As I have mentioned in other threads, I'm a fan of dealing with all things 'non linear' (EQ, compression etc...) outside the microphone.This thread seems to be opening up a whole new can of worms I'd never thought about, with respect to if, when, and where to use EQ in the signal chain......
One thing to add is that many engineers are operating under a time-crunch in the studio (due to artist budgets). In those situations, “fixing it in the mix” often isn’t feasible. There are many situations where I have grabbed a mic that I knew would soft-clip or band pass the source I was recording so that I would get what I needed to begin with. I don’t always have the time to go though and high-pass or transient-shape all my tracks, and in those cases, microphones that behave in a known (but not linear) way are invaluable.When it comes to recordings, then we are talking about dealing with signal processing in a DAW.
Back last century (for Peavey/AMR) I designed an op amp based direct box (EDB-1) powered by phantom voltage. I was able to extract enough current and voltage to supply a BiFet op amp, with volts of output swing.Question: Aesthetics aside, most OPAs need 32 v rail to rail. At that voltage the most current available from phantom pwr would be 16/v drop across 3400 ohms (2x 6.8k phantom pwr Rs in parallel) =4.7 ma.
Is that enough to drive a 600 ohm mic input w/o clipping?
With modern opas, that's way more than enough. Low noise true jfet opas need 300 nanoamps per channel on the low end and under 2 milliamps per channel on the very high end. Maybe a couple years ago there wasn't enough power but now you could easily run two, four, even potentially 8 channels on phantom power alone now, and that's with THD <0.0001% and negligible noise. These opas are designed to take microphone capsules straight to line level impedance too, so you don't even need additional amplification afterwards.Question: Aesthetics aside, most OPAs need 32 v rail to rail. At that voltage the most current available from phantom pwr would be 16/v drop across 3400 ohms (2x 6.8k phantom pwr Rs in parallel) =4.7 ma.
