My buddy's board eats these things like jellybeans, like 10 or so in the last two years,
I noticed it had no short-protection, but assumed it was deep inside the box where it would not get fatal abuse. 5/year? I'd cobble a 5534 or even a TL071 onto the SIP-pins: a plain-vanilla amp that works is better than an amp that dies when the musicians are hot.
Obvious first step is some current limiting on the output. Back-diodes on the output B-E junctions, with the Vbe bias-net, would limit the voltage across the emitter resistors to about 1.2/Re. If Re is 33Ω, 36mA. If it stalls in that condition, 0.54W in the transistor. But then you have to check the volt-amp stage... hmmmm, also 0.56W worst-case, kinda hot (though kinda unlikely). Another 100Ω in the collectors would cut that in half, without much effect on normal operation.
Is that resistor-ratio on the Vbe multiplier right? It looks like 1.6*Vbe, which underbiases the outputs. They may be idling at 0.050mA, awful poor. Output impedance will fall from 600Ω teeny-signal to 35Ω large-signal, too much variation for typical 1K-10K loadings. A richer bias might take some grit out.
Overall, the only thing I really like is the logo. The circuit seems vanilla. There's little excuse for underbiasing an AB output in discrete audio. The input stage current is large enough to be a noise issue in the balanced line-in circuits
posted by silent:arts. In fact a 5532 would give lower noise, fine sound, and be failure resistant. This 0.25mA input emitter current is more for 1K-2K sources than those 13K sources. The 5532 minimizes at 9K and will still be low noise at 13K.
output stage improvements in dissipation, like parallel devices with current sharing resistors, and some heatsinking.
Or that. Not knowing the load, I dunno if it needs more output, or just protection from "accidents".
sussed out the necessary parts to buy to rebuild a Farfisa organ.
Now, that's going TOO FAR!!! You will give DIY a bad name. There is no excuse for that. Let dead dogs lie.
