I own a few Grommes G5M tube mixers which I love, and for years I've wanted to make a stereo version of one, with four inputs switchable to either or both outputs.
The design itself should be fairly easy to replicate, with a switching network of 4-pole 3-position switches. My question concerns the power supply.
I could easily hack the supply from an existing unit; I never use the 12AU7-driven output stage, so removing that tube and adding the requisite 12AX7 for the second output / EQ stage would give me a total of 8 x tubes, so a current draw somewhat less than 10 mA (the original transformer is rated at 320-0-320, 20 mA.
That said, I'd rather not cut up a perfectly good mixer. My question is:
-Do I try and replicate the original power supply, which means finding a high-voltage, low-current transformer, which seem oddly difficult to come by?
-Do I take advantage of modern components and build a solid-state, even a regulated supply?
Even a brief scan of the forums--and I am an avid reader--shows no consensus on tube power supplies. Many people feel that unregulated is fine, even AC on the heaters is okay. The original unit uses a 25V secondary for DC heaters, which may be one of the reasons it's so quiet.
I'd love any expert opinions. My gut is to keep it as simple as possible, but that doesn't mean forgoing modern technology if it's called for.
Many thanks!
Many thanks!
