Yeah, the circuit I first wanted to try this with has only a single bipolar transistor in it.Not at all, as far as i'm concerned. That 40-45v's assuming the circuitry would draw next to no current though (you still have the 2x 6.8k inside the preamp)
That's a FET on the schem between the capsule and the circuit block (labeled 'FET bias / output circuit') that has the single bipolar buffer Q in it.Bipolar transistors don't have high enough input impedance to work effectively as a condenser capsule buffer. There is a reason why every mic circuit you have seen starts with a jfet.
Good catch - no, I just failed to draw it (focussed on the output arrangement).Is your intention to put the capsule bias from the center tap directly on the FET gate? I would think a 1000 pF capacitor would be needed to couple to the FET gate.
The FET is 2SK660
the bipolar is 2SA1174 (collector current 0.05 A)
I'm not an EE; just a mic hobbyist, so I don't know how to calc bias current.Bias current?
50 mA is the maximum. What is the bias current?
Bias current of the JFET and the bipolar stage has to come from the phantom power.
Both together have to be around 2mA if you do not want to go below 40V at the cartridge.
an electret containing the 2SK660 FET
I don't know what the diodes are
disconnecting the primary of the trafo from the circuit and only using it to tap off the phantom voltage
I don't think it's a Zener; I drew it just as AT did (back when they published schems [sans component values]) - a circle with a line to the left (never seen that symbol on other schems); others have speculated it's a current regulating diode.The 2SK660 is made specifically for buffering electret capsules; it contains the gate bias resistor (or equivalent, possibly made using the small leakage current of a PN junction) and a JFET made to be able to run with 0V gate-source.
The capsule head with that JFET is basically like the small electret capsules you can get with built in buffer that just need a resistor to the drain from a voltage source, and you capacitively couple the signal from the drain/resistor junction.
Probably a zener diode operating as a basic regulator to drop the phantom power voltage down to 9V or so. You can't put 40V directly on a 2SK660.
If you are going to disconnect the transformer just take it out. To tap the phantom power you just need two equal value resistors each connected to pins 2 and 3. Join them together and that is your center tap. 2K each would drop another couple of volts from the phantom power; is that why you are trying to use the transformer instead of resistors?
